does a Neuspeed Short Shifter from a 2003 Audi TT fit LCR?
p1tse
294
looking like this:
Stu_pot
Fire Starter
Mar 26, 2004
374
Near Blackpool
It 'might' do. It depends on the fitting for the selector cable. One is a ball type and the other is a straight pin with circlip.
However, I have the very same shifter from my S3 and I purchased the Forge fitting kit (their kit supplies both types), wound out the Neuspeed pin and wound in the Forge pin.
Works fine.
Stu_pot
Fire Starter
Mar 26, 2004
374
Near Blackpool
I'll explain it in simpler terms :)
You can make that one fit.
You buy a FORGE fitting kit. I.E The fitting kit for the quickshift they sell.
The FORGE fitting kit has BOTH pin type and ball type cable fittings.
Choose the correct fitting for your car and replace the pin or ball with the correct one...
honeyman
Pirates
Oct 20, 2004
614
Northampton
Should fit as I have one of them on my MK2 Cupra, which uses the same gearbox as MK1 LCR only thing I found was I had to open up the hole on adjuster slightly, I had an EIP on my LCR same as neuspeed but not so bling.
p1tse
294
thanks
it's mine the above and looking to sell and making sure on advert when it goes on ebay
