Hopefully you’ll get a recommendation for a PDR company near you. Excel-dents near me (Aylesbury) charge around £50 a panel.
PDR will probably remove the dent successfully. However, as there’s also paint damage, it won’t be back to ‘like new’ (which is what the OP wants) without getting the paint scratch in the dent and the separate paint chip sorted too.
Doing a DIY paint repair (touch up pencil or a paint repair kit like a Chipex kit) after the dent had been removed is likely to be visible, and the paint finish and colour match may not match the original factory paint exactly.
@pbird; I think you be best speaking to a good SMART repairer to see if a localised repair would give you a ‘like new’ result. If not, then you‘re probably looking at a body
shop repair, which might be quite costly, depending on how large an area they feel needs to be repainted to ensure a perfect match in colour and finish between original paint and new paint.
