Changed cambelt now secondary water pump not working?
Jamie225
322
Leicester
I changed my cambelt and water pump on my lcr at the weekend. Had a rite nightmare. Started it up after doing job and got a misfire. Almost shat myself thinking i had bent valves but turned out to be a dodgy coil pack so i replaced all 4 and all was well. Then i noticed that the secondary water pump wasnt working. It worked a couple of times after but now doesnt work at all. All connected up but nothing? any ideas?
danny m
321
i had this after the garage did my cambelt and water pump change, turnt out to be two of the four wires going to the secondary water pump had been cut/broken!!!!:censored:
Jamie225
322
Leicester
i only have 2 going to mine? dont suppose you know where the were broken do you?
danny m
321
from the charge pipe on your left the hose goin from there to the intercooler is a big clip thing that clamps around the hose for the wires to be attached to. hope this makes sense if not let me know and i will try and add a photo.
