beeps on ignition
Chuku
16
Hi, my Ateca 2022 does lots of beeps when I first start it, like tests of the indicators..
I think its due to some OBD coding, anyone knows how to disable it?
Thanks!
Tell
hmmm has it always done it or did it start after you did some coding ?.
My Mib2 is quite no beeps. Could be an error you are not seeing ?. Where a scan would reveal that. Do you have the dreaded telematic SOS box on these newer ones.
Other than that it would be a Mib3 thing.... people with Mib3 might be able to help. Not touch screen beeping. If that's an option I'd take that off. Now I'm out of ideas.
Tell
If it's Obdeleven Pro you have have to go thru the history file and carefully undo what you did. If you used micro payments apps where it's not clear what they changed then pass on reversal. Why one doesn't support the apps since if you have a rogue one, tricky to reverse.
Chuku
16
Yes its Obdeleven pro, I'll try to view history... is it possible to get an entire history and not per module?
Chuku
16
SOLVED!
It was the seat belt warning that I changed from EU to US.
It seems that in US it beeps when you ignite the car without seat belt on. which differs from the EU version.
Changed it back to EU and the chimes stopped on ignition :)
Reactions: Tell
