45mm lower hmmmm?
Tomibz
61
Wakefield
Not the best pic to choose from but only one I have atm.. The thing is I've got 45mm spax lowering springs and well I'm not sure if it will rub real bad or it will be ok, its on VRs rims with 205 45 17 tyres on, what do you think it will be like?
Altech
Ibiza PD170
Oct 3, 2007
1,996
London
The fronts will most likely rub due to the 45 profile tyre. Even at standard right height a 45 profile tyre on a 17" rim will rub. If you butcher the plastic arch linings then you should be able to stop the rubbing. Or just get 40 profile tyres fitted
Stance93
I know this thread was years ago but did the tyres rub on the arches at the front on full lock?
