1.4 TSI idle RPM drop
Dec 4, 2022
Dear All,
I am experiencing the following issue in my Seat Leon FR 2013 1.4 TSI CXSA.
Most of the times when I start the engine, the RPM is going down, almost stalling. Even dashboard lights are flickering.
There is no error code, check engine light or anything.
I checked the followings:
-Battery (fully charged)
-Throttle valve (cleaned)
-Spark plug (new)
-Ignition coil
-MAP sensor (seems clean)
-PCV valve (new)
If you have any suggestion please let me know.
Thanks,
Mark
queen
~Nassia~
Nov 29, 2010
702
63
Athens, Greece
Seems like you have either a vacuum leak, a faulty throttle pedal position sensor or a faulty idle air control valve. If it occurs only on idle then it's most likely the valve, though it usually throws a code.
