I was just looking and this came in my sight///
is this a good kit for the cupra ?
the price is also nice...
A big seller for us here at MJM, the SACHS VR6 clutch kit with G60 flywheel combo is a great way to upgrade your MK4 2.0L, TDI, or 1.8T clutch kit and go with a bigger, beefier 228mm clutch and flywheel package.
Rated at near 300 ft/lbs of torque, the SACHS VR6 clutch kits can take nearly all you throw at them - all while retain stock like pedal feel. The Eurospec single mass billet steel flywheels tip the scales right at 14 pounds and come with factory ring gear.
The Corrado G60 and Passat 16V's also accept the VR6 clutch. This kit is a great upgrade for those models without spending the big money.
All kits includes:
SACHS VR6 Clutch Disc
SACHS VR6 Pressure Plate
SACHS OEM Throw Out Bearing
Eurospec Single Mass G60 14 lb. Flywheel
All OEM pressure plate (6) and flywheel (6) bolts ...
cost $399.95
let me know what you think about it
All kits includes:
cost $399.95
