Lozzy15
Servicing Service guide - How to change the oil & filter - 1.4 MK3 Leon
Hi guys & gals,
A nice simple guide today on how to change your oil & filter at service time. I'll also show how to change the pollen filter.
I won't be talking about the air filter as I have a custom one on my car so there's nothing for me to change/clean just yet. Another point to note is that this engine doesn't require a fuel filter change as it's built into the fuel delivery unit in the fuel tank i.e it has a 'lifetime' filter o_O
Parts & Tools
For this you will need the following parts:
Sump plug - N 902 889 01
Washer - N 013 815 7
Oil Filter - 04E 115 561 H
Pollen Filter - 5Q0 819 644 A
Oil (5W-30) - VW Spec 504/507
From TPS, these genuine parts came to a total of £38.46 including VAT. With an air filter it wouldn't have been much more.
The tools you will need are:
19mm socket & ratchet
T25 & T40 Torx bit & driver
Oil filter wrench OR oil filter puller (74mm)
Oil catch pan
Jack & axle stand, or access to a lift/ramp
Rags
Changing the oil
To begin with make sure your car is on level ground. Then securely raise it at the front end. I jacked it up where the rear of the front wishbone attaches to the sub frame. I kept it on the jack but placed an axle stand under the sill should the jack fail.
Once in the air, you need to remove the under-tray. This is held on with 11 T25 & 3 T40 Torx bolts in the following locations;
One at the centre front:
5 either side going from front to rear:
3 at the rear of the under-tray (T40):
Once removed, the rear drops down and the front unclips from the car, allowing removal.
Now you have access to the under side of the engine compartment. Locate the drain plug at the rear of the engine:
This nut is 19mm. Position the oil pan under the sump, and then slowly undo the plug. As it gets looser, push it against the engine while continuing to undo it. This will prevent the oil from suddenly gushing out as it comes out fully. Once fully undone, quickly remove it, or drop it into the pan and retrieve it later. Ensure to move the oil pan as required while doing this procedure. Allow the oil to drain into the pan:
DO NOT START THE ENGINE FROM THIS POINT ONWARD!
While the oil is draining, remove the axle stand and lower the car down on the jack to allow the engine to level out to ensure as much old oil as possible drains out. Keep an eye on the catch pan while it is draining as the flow may change as it slows.
Pollen filter
While the oil is draining you can change the pollen filter. It is located inside the glovebox. Open the glovebox and push in both sides towards each other to allow it to drop down:
Then pull the plastic cowling around the media unit towards the passenger seat to unclip it. Once unclipped, remove. You can now see the filter housing. It has 3 clips at the bottom that need to be pressed down to release the cover:
Pull the cover down and it will release, allowing removal of the filter. The filter simply pulls out:
Old VS new:
Once removed, replace with the new filter:
Refit the covers you removed. They are reversal of removal. Then push the sides of the glovebox in the opposite direction and push it back into place. That's the pollen filter all done.
Oil filter
Check that the oil flow from the sump has almost stopped, indicating that most of the oil as drained out. Raise and secure the car again. With a new sump plug and washer, replace it into the drain hole and tighten then torque to 30NM. Clean the area with a rag:
Once done, locate the oil filter on the front of the engine block. Position the oil catch pan under it and proceed to loosen it with the oil filter wrench/filter puller. Turn in a anti-clockwise direction to undo:
It may be fairly tight so be gentle but firm. When it loosens off, oil will exit the filter & engine block so have a rag to hand. Continue to remove the filter and place it where it won't make a mess:
Clean off any excess oil that leaked down the engine block. Next, take your new filter and lightly apply a film of oil to the rubber seal on the mating face:
Now replace and tighten the filter by hand. If you are using an oil filter puller, torque to 20NM. If you are using a filter wrench, tighten the filter as much as you can by hand, and then give it a very slight nip with the filter wrench.
Once done, the under-tray can be replaced. It is reversal of removal.
Refilling with fresh oil
With the under-tray replaced, fully lower the car to the ground and ensure it is level. At no point start the engine while doing this. If you need to move the car, release the handbrake and push it by hand.
Remove the oil filler cap, and either using a rag around the filler neck or by using a funnel, pour in fresh oil. After around 3 litre's has been poured in, check the dip stick for a level. Keep pouring until the dip stick indicates around the half way mark.
Replace the cap and briefly start the engine (around 10 seconds) then turn it off again. Give the oil 5 minutes to settle then check the level. It should have dropped as oil made it's way around the new filter. Fill again until you are almost to the MAX marker on the dip stick.
Start the engine for a few minutes then switch off. Again allow 5 - 10 minutes then check the oil level on the dip stick. Add more if needed. You should use a total of around 4 litres to fully fill the engine to max.
Be careful not to overfill the engine as you will have to drain out any excess. Excessive oil can damage an engine just as badly as too little oil!
With the oil replaced, the service is done. If you need to change the air filter then do so now. It isn't difficult to do and should take no longer than 5 - 10 minutes.
Ensure you dispose of the old filter and oil at a certified waste disposal site. Most council refuse sites allow you take it there for disposal.
Service complete!
If you need to reset the oil interval light on the dash then follow this procedure:
With the ignition off, press the mileage reset button once. The mileage should appear.
With the ignition off, press and hold the mileage reset button, then turn on the ignition.
Keep holding pressing the button until the dash asks if you want to reset the oil light.
Release the button, then press the button once to reset the oil service light.
To remove the inspection interval light:
Do the same as above, but when it asks if you want to reset the oil service light, keep the button pressed in until it asks if you want to reset the service interval.
Release the button then press it once to reset the service interval.
As always, any question or suggestion then post or message me.
Regards,
Lozzy
Author
Lozzy15
Views
6,484
First release
Last update
5.00 star(s) 1 ratings
More resources from Lozzy15
