MK3 ST - 2nd OEM style boot light
dynamis_dk
51
17
Barnsley, Yorkshire
So having finally figured out roughly what parts I needed today I've had a crack at sorting out a 2nd boot light as I've always felt it would be a bit nicer to have one on each side. EDIT: Updated post to show new image with matching LED's on each side - much better :)
I've tried to take a bunch of photos as I've gone so if there is any interest, I'll try to knock up a guide on how I've got about it.
dynamis_dk
51
17
Barnsley, Yorkshire
I don’t see why not, the process to remove certain trim sections might be a little different but otherwise I can’t think of any reason it wouldn’t work the same.
dynamis_dk
51
17
Barnsley, Yorkshire
I did look to route things across the roof but having looked at the trim and wasn't 100% sure on what's under the headliner, I decided to route behind the boot lock trim as it seemed nice and out of the way. From what I can tell based on images of the hatch, the boot lock cover is just deeper but I'd expect you can run the cable in the same way as I have on mine
Now I've got mine finished, I'll knock something up over to give a run over how I went about it.
Reactions: Walone
Mo_86
135
39
UK
I have the led light, does anyone have a link for a brighter one as its so dim.
TripleBob
307
198
Mo_86
135
39
UK
I got some decent LED fittings from aliexpress. Exactly match the OEM fittings/connectors and MUCH brighter than OEM
edit - this is the kit I used to add an extra boot light:
Perfect thanks, any pics of where you took your wiring?
Mo_86
135
39
UK
Seems as though i have a different light in my boot; part number: 8j0947409b
