If i remember right there was change in instrumental cluster so the previous 2020 didn't have it. Hard to say if that could be some how done with firmware update on the cluster.
Hi Antera! thank you for your explanation, the original module has 3 cables and in the photo it replaces only one. Is it still OK? Is it left original for the two missing ones?- Disconnect battery iff you want or keep igniton off.
- Release the airbag
- Disonnect the airbag
- Replace the TKL module
- Put airbag back
- Reconventie Battery iff you did so
- Drive
Yes !Hello ! Is it possible with obd11 to have this menu for Esc and Tcs ?
Yes, I also have an 2020 model (Xcellence trim) imported from Poland and I also don't have those settings...If i remember right there was change in instrumental cluster so the previous 2020 didn't have it. Hard to say if that could be some how done with firmware update on the cluster.
Thanks again.Yes !
the coding is this:
control unit 03 brakes ,
long coding you move to the bytes, drawing 0101010101
you go to the bottom moving all the way to the right, count 6 going back to the left and you find an entry starting with A, mine was A2
Remove bit 01 and put in bit 02 - the entry becomes A4 .
Scroll to activate.
finished
I see you managed to encode, great!Thanks again.
P.S. I ordered a KLR module for myself that has outputs for all three plugs.
I took this exact one from the auction you provided. so the one from this auction with an output of 3 didn't work for you and you bought another one now or Is the one from the auction you are giving is correct ? someone wrote in the comments that it works with Seat Leon. It hasn't sent yet and I have a chance to cancel it.I see you managed to encode, great!
I bought this, but it didn't work and I returned it... the seller told me it was right for my car...
The steering wheel worked normally but it told me to keep my hands on the wheel
the seller says it is correct for my car, but it didn't work. i fitted the capacitive steering wheel after purchase, it was from an ateca, so maybe the decoder is differentI took this exact one from the auction you provided. so the one from this auction with an output of 3 didn't work for you and you bought another one now or Is the one from the auction you are giving is correct ? someone wrote in the comments that it works with Seat Leon. It hasn't sent yet and I have a chance to cancel it.
ok now I understand. I have the Excellence and I also bought the Excelence version, only with the TA button. In that case, I'll wait for the shipment and let you know if it works.the seller says it is correct for my car, but it didn't work. i fitted the capacitive steering wheel after purchase, it was from an ateca, so maybe the decoder is different
Its the same steering wheel. No Difference. De module works perfect without any issue for a while nowthe seller says it is correct for my car, but it didn't work. i fitted the capacitive steering wheel after purchase, it was from an ateca, so maybe the decoder is different
thanks i will give it a try !Yes !
the coding is this:
Scroll to activate.
finished
Ok do you know how to put it in service mod using obd11 ? ThanksGoogle is your friend. Is no coding is adaption in ABS. It is selfexplaning
Unit 03 Brakes / Basic settings /Start lininig change mode.Ok do you know how to put it in service mod using obd11 ? Thanks
I have tried cupra view but no luck, I have active view 7 and 8Hi Everyone,
I have been having a play with OBDeleven with my car (FR First Edition) and have managed to code some things and thought Id share what I have found and create a thread where people can share there findings for us all.
I have managed to code:
Cupra Display
Lane Assist Point Of Intervention (Have yet to test, but should keep the car more central rather then let it almost drift out of lane before kicking in)
Lane Assist Set To Last Setting
Lane Assist Warnings Turned Off
I know a lot of people find lane assist is already to sensitive (its already set to lowest from factory), so I might have found a solution to this too. So you can turn it off and it will remember this setting each time the car is turned on etc, so now you can make it sensitive for the motorway and only turn it on when you want it.
Cupra Display:
Module 17 (Dashboard) -> Long Coding -> View Activation -> Set All 16 Views to active -> Write To Car
Lane Assist Point Of Intervention:
Module A5 (Driver Assistance) -> Long Coding -> Point Of Intervention -> Set To Early -> Write To Car
Lane Assist Warnings:
Module A5 (Driver Assistance) -> Long Coding -> Lane Assist Off Text -> Set To Disabled -> Write To Car
Lane Assist Settings:
Module A5 (Driver Assistance) -> Long Coding -> Configuration For Lane Departure Warning K15 -> Set To Last Setting -> Write To Car
Let me know what you guys find
I have tried cupra view with vcds activated view 7 and 8 but no changeHi Everyone,
Cupra Display
Cupra Display:
SFD unlock, open bonnet, parking mode and handbrake. You can activate all views. I dont remember wchich one is cupra. I think its 6 or 8
What interface do you have ? Only obd11 have with pro/ultimate plan, odis with geko or token, VCDS/vcp/VCtool with token.I have managed to do lane assist, but no new view how to unlock SFD?
