Yes sorted it
The oil level sensor was playing up just a constant yellow light pretty sure the cold temperatures outside can effect it btw if not that then:
if the oil level is fine then don't worry the fix for this is to disconnect the battery for 10mins and reconnect it thats the negative cable iirc
the light will then go out, had mine looked at with VAGCOM at the garage no error codes what so ever, just had a service done, oil change filter etc so hopefully thats the end of the
problem, they didn't change the sensor as no fault code, so it will be fine to drive
the light is supposed to go out if low on the oil, when you open the bonnet top it up and close it, thats supposed to reset it, but more often than not it doesn't work disconnect the battery and all will be fine, as long as its not the red oil pressure light if you see that don't drive it get it towed to a garage for investigation
