XDS and off I go!!
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,480
Northumberland
Turned XDS to High (setting 2) in vagcom today and what a massive difference!!! Turns out this car CAN corner. Even in the wet
Get it sorted
Deleted member 74601
Just the XDS and large MFD readout I have to do now. 1.6TDI with mad XDS won't be quite as exciting as yours though :p
Only thing about MFD reading is if I want to go abroad :D
shnazzle
Sep 9, 2011
3,480
Northumberland
Why? :) I actually have no clue wha I've done with that one...particularly as I could find any large speedo display.
I set it to Rest of World, and then un-ticked the "Alt. speed dis". Then set units to mpg...
I have indeed lost the kmh, is that what you mean?
How do I get it to show the large readout?
Why would it make it better to set higher? Surely they are all set the same?
No, Cupras are set to 2 by default, which is stronger. Why the rest aren't set as strong I don't know.
Benjic2
1,029
XDS is set to strong only on the FWD cars that have 345mm brakes as standard across the VAG range ( e.g Rocco R, Cupra/R ). The XDS works by braking the inside wheel when cornering to improve turn in and provide better traction on exit, so the brakes are being worked harder and get hotter than normal, which the 345mm brakes can handle with ease. The cars with smaller brakes only have it set to normal because they will suffer from more brake fade when you are gunning it, especially on the track. Then there is also extra brake wear which comes as a result, but in reality you are not going to be hammering it everywhere/every day and is obviously only a small trade off for the better corning abilities :)
Another free VCDS mod that I would suggest is the brake assist/booster that alters the signal to the brakes to provide a little more pressue than you request on the brake pedal, this gives the feeling of more responsive brakes. When I sold my car and put it all back to standard settings, I noticed how the brake felt mushy and crap again once I turned it off. It's worth a go and if you don't like it then just swap it back :) It works like a more aggressive throttle map does, except on the brakes :p It's not a big of a difference to feel as the XDS is, but every little helps.
shnazzle
Sep 9, 2011
3,480
Northumberland
Ah! I read about the braking bit but never put it together with the 345 discs.
Makes sense.
I'm more than willing to sacrifice a bit of wear/tear on perishable parts for the sake of having this much better cornering.
Wish I did this ages ago.
I considered the brake boost, but I damn near put my head through the windshield when I switch cars as it is :)
Al
7,326
9
Yip. Had one on my old MK2 Leon Cupra and just took the same one off my FL MK2 Leon Cupra.
XDS is nothing like a mechanical diff.
