L3DNT
Hi all, just a quick question... had all the juddering/erratic idling/hesitation problems that ive read loads about. Throwing up several codes,
"fuel trim lean",
"pressure drop between turbo & throttle valve",
"O2 sensor circuit malfunction bank 1 sensor 1"
so from what ive read, could be MAF problem,
but also has "Cylinder 1, 2, 3, and 4 - misfire detected"
Ive disconnected MAF and car drives completely as normal, so looking more like MAF problem.
So my question is: If it is the MAF, would that cause "all 4 cylinder misfire" warning codes??
and could i be overlooking something else? Maybe all coil packs gone? but would that be "fixed" by disconnecting MAF??
All v weird
Any suggestions or advice?
Thanks in advance
L3DNT
"fuel trim lean",
All v weird
Thanks in advance
L3DNT
