Mar 25, 2009
1,245
bath
hello folks,
just recently i have notice my car making a weird squeaky rattley noise when stopped or coasting, sounds like it coming from behing the center air vents/cd player,
when i open the bonnet with the engine running, it was rocking quite significantly forwards and backward. is that normal? it then stops rocking when i touch the throttle which might explain why it only happens at with clutch in/stopped/coasting etc?
any help
give it a good hard rock ad see if you can replicate the noise, or get someone to do it whe you are sitting in the pilots seat :)
