Just thought I'd ask before jumping in and doing it, at the moment the Cupra's wishbones are currently spot welded together in all the places marked with a red dot on this picture;
There is around 30mm's gap between each spot weld, now I was thinking where the two plates meet, welding a few 15mm lines in between the dot's. Now I'm not going to run one complete weld due to the risk of warping the wishbone, however closing up some of the gap's with weld should surley reduce some flex.
Has anyone got anything to say before I do this, reccomended or not? Any different methods that I should use? Currently I'll be using a MIG welder on it.
Any help, opinions and advice is much appreciated!
