wiring help needed!
paul cupra
i've just bought some Vibe KE-60 speakers which come with tweeters and cross-overs, my problem is that on the cross-overs there are connections marked TW- -3db 0db WF- WF+ IN- IN+ as i'm a bit stupid does anybody know which wires go where please:think: :shrug: :confused:
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
In+ is the terminal to wire the positive side of the speaker wire coming from your amp or head unit
In- is the terminal to wire the negative side of the same speaker wire.
WF+ is the terminal that you connect to the positive side of the woofer (big speaker)
WF- is the negative terminal that matches this.
TW- is the terminal that you connect to the tweeters negative connection
TW0dB is the terminal you connect to the tweeters positive connection, OR,
TW-3dB connects to the same place IF you want to attenuate (lower the volume of) the tweeter.
So basically...
IN+ and IN- take the feed from your stereo/amp
WF+ and WF- are the feeds from the crossover to the woofer speaker
TW-, TW0dB and TW-3dB are the feeds from the crossover to the tweeter
paul cupra
awesome, cheers mate will now spend the rest of the day trying to fit them
RobM
Sep 27, 2006
4,982
Southampton
It should be fairly straight forward to be honest. Just remember that TW is the tweeter and WF is the woofer and all you then need to do is make sure you get positive and negative the right way around.
If, once fitted, you find the tweeters are too harsh or too loud, you can use the TW-3dB instead of TW0dB and it cuts the power to them a bit.
paul cupra
cool, it all sounds so simple when you know what all the abbrevations mean!
