Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
I think its just a case of unbolting the blade and the motor from the tailgate and unplumbing the washer jet. think its quite simple, im looking to do mine over the weekend.
you have to remove the steering wheel. i ahd to have mine replaced on my 1.6 Sport, had it done through my work tho, so i have no idea how to remove the steering wheel, or disconnect the airbag
Disconnect the battery to be safe. Remove the steering wheel (3 torx bolts one at 3, 6 and 9 o'clock). Airbag will pop up, just disconnect it by pulling the yellow wire out at the steering column end. You will then need to remove the big nut that holds the steering wheel onto the coloumn (you won't miss it). Then I think the wiper stalk pulls out, but be careful not to break any of the connection pins. Then slide on your new one and repeat the process backwards
