Wing Mirror Help Req'd
craigomills
Candy White FR TDI 170
Mar 31, 2005
195
Derby
Some clown caught my drivers side wing mirror tonight whilst driving past me.
The Bloke stopped and we exchanged details (his Mini was also damaged).
I now need to buy a replacement. When I looked at it it seems that the damage isnt too bad, the motor still works for the direction of the window and the mirror still rettracts.
Can I buy just the parts that are broken or do i need a complete assembly.
The bits that are broken are the glass, the black painted front cover and the plastic surround.
Is there a technical diagram anywhere with part numbers I can see?
And finally, how much do you all reckon it will cost me?
red line fun
602
12
Scotland
you might have to buy the complete assembly, others on here with more knowledge will advise i'm sure! with a lot of these assemblies you're forced to buy the whole lot, otherwise dealers etc would be left with odds and ends.
craigomills
Mar 31, 2005
195
Derby
I know you can buy the chrome covers (might force me into changing them now), and you must be able buy the glass.
The plastic surround is the bit im most concerned about.
Also, how do you replace them????
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
the colour coded cover , glass and main body are seperate units, the same happened to me last week and was quoted 130 plus vat for all three plus painting.
craigomills
Mar 31, 2005
195
Derby
kin ell thats expensive!!!!! so do the covers not come already painted?
craigomills
Mar 31, 2005
195
Derby
cordobabrendy said:
yup especially when the other person did it when my car was parked and i wasnt in it!
camera evidence is being gotten tho..
do u reckon it would be cheaper to get the chrome covers instead?
(i was thinking of doing it anyway!)
Fidge
SEAT Enthusiast!
Sep 9, 2004
480
Southampton UK
I paid £70 for the main mirror assembly and £9 for the back plate (painting cost me another £20) dunno how much the glass is!
Fitting is easy just take door card off by prising inside door handle, plate off (this is trickiest part) then screws behind it then undo screws at bottom of door card to remove it, then prise off the plastic plate behind door miirror inside and undo the screws and disconnect cable then pull away and then fit new mirror assembly.
The back plate of the mirror assembly just clips on (when painted) and so does the glass (don't forget to connect wires to spade connector on glass if heated mirrors)
HTH
craigomills
Mar 31, 2005
195
Derby
HTH
I'll get on to Seat in Derby today to see if they can get the parts in time for the car going in a week on friday for a bit of warranty work.
Cheers.
Pabs
5,936
Basingstoke
heated glass is circa £25 from a vw dealer, so prob the same from a seat dealer.
Try ebay though - picked myself up some bargains there :)
TheOtherSimon
454
The lower black plastic cover is part of the main assembly, and you can't buy it separately (annoyingly). So for a new one that's £70.
At least you end up with a spare motor...
Simon.
craigomills
Mar 31, 2005
195
Derby
Simon.
the stealer has quoted me £203
Fidge
SEAT Enthusiast!
Sep 9, 2004
480
Southampton UK
Simon.
The back plastic cover (that is colour coded) doesn't come with the main assembly and you can buy it seperately as I did so only a month ago!
