Guys the wing mirrors work correctly when I turn the passenger side one up down left right but drivers side one also operates passenger side.WHAT GIVES THERE. Also wifey just told me that a couple of weeks ago only the drivers side mirror folded up.
NATH, Noticed you have colour coded wing mirrors.Are they sprayed by yourself or bought as is?
Looks the biz anyway.
Do you use millers additive.If so is the car dependant on it after you start using it??
What about the so called gains.
Just been out to the car again and the mirrors are still not right.The drivers side still works both mirrors.VAGCOM dealer it is then.
Moving the drivers mirror via the switch then passenger one is not the point really as the drivers one moves both.
