nicky_hud
hi all,
ive owned my tolly for about a week and a half now and have found a couple of little faults, one was the memory seat problem(still not solved) and the other is the near side mirror reverse thingy. sometimes it works and sometimes it doesnt. also on occasions i will stick the car in reverse and nothing happens but when i take it out of reverese the mirror moves up to adjust back to where it thinks its just moved from
does anyone know if there is a switch on the gearbox/linkage anywhere what controlls this? or if there is any other common faults that may cause these problems. also could the mirror problem be connected to the memory seat problem as ive read in the user manual that when you memorize the seat you also memorize the mirror position? these little problems are nothing realy but if its something stupid that can be easily fixed then i feel its worth doing.
they obviously worked at some stage and it would be nice to have them working once again.
thanks for your help, any input would very appreciated.
nick
nick
