Windscreen Vents
steveoelliott
55
Hi,
Does anyone know how to remove the windscreen vents. I have a rattle coming from that kinda area and I wanna see if I can see what it is.
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
guessing you mean the front screen fan have heard of rattle behind the dash but this was caused buy the face vent pipes knocking this could be your problem is it all the time?
steveoelliott
55
Yea but worse when cold.
I had a quick look when I took the side panels off the dash and the pipes weren't knocking there. It could be further in behind the dash where I cannot see though.
Bet its a F**KER to get to them there.
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
it's amazing how much those heater ducts cause rattles
I had a rattle the same as the original poster but only when cold
removed side pannels, insert strips of foam between ducting and whatever they were touching/close to
no broblems with rattles now :p
steveoelliott
55
Surely u can only get to the outer parts of the ducting tho. Also what type of foam strips did you use and where can you get them from?
steveoelliott
55
So do you reckon that if i take the side panels off and ram some rag up there as far as I can. Just when I looked b4 you could only get around the outer vents.
Nath.
Jan 1, 2006
8,620
16
foam as in car wash sponge
when you remove the side covers you can see with a torch quite a way in behind the dash
also if you remove the radio you can see up behind the middle vent ducting
get in there and have a good old rummage, don't be scared
