19's will go on no problem, but i think you might be pushing it with the offset at ET35.
I've got 19" BBS with an offset of ET44 and they are just about right, any less and they would stick out past the arches and A. Rub on the arch line, and B. They would be illegal for the road.
If i understand offset correctly the higher the number the less the wheels stick out. So the the ET50's maybe ok, as long as they give enough clearance for the brake calipers??
