robepton
Practical performance!!!!
Dec 27, 2008
110
peterborough
Are the Fabia VRS tdi exhaust systems the same as on the FR and the Cupra?
I know the milltek exhaust for the fr TDi and the Cupra are the same apart from the tail pipe being slightly different.
I'm asking because there is a lot more choice for the Skoda than Seat and it's the same engine and chassis. I'm making the assumption that the under belly is all the same.
I would love to here from somebody who has fitted on.
I did read a few threads on this but there was nothing that was concrete.
It is possible that there may be a slight difference in the mount bracket locations for the backbox.
I only say this as I know Blueflame do an exhaust for the Fabia vRS but they say it will not fit the Ibiza Cupra TDI.
Unfortunately I haven't had the chance to check one out in person to confirm it.
I'll have to see if i can get sneek round a fabia vrs next time i see one.
Scorpion also do a cat back for fabia vrs.
You would think if they did fit then capitalise on the opportunity.
Might give Blueflames a ring see what they say. I might even see if they'll do me a custom.
I've also thought about using pipewerx.
Undecided between a new exhaust or a H&R/bilstein suspension kit with F ARB. But it's always good to now ya options.
I know the floor plans are the same because i checked them on vagcat. The downpipes are the same because the milltek part numbers are identical. However the part numbers for the cat back are different. Might just be the tailpipe that's different.
Thanks for the input.
its prob more due to the lenth of the rear silencer due to how far the bumper sticks out or something? ill be damned if it dont fit... they share the same chassis same engines, same floor plans why would the exhaust rout change that much?
