I seem to be having no luck with this car.
I fixed the door seals and am getting the car dried out, but driving today another problem has cropped up...
I was driving along the road and the battery light started to flash. I had the stereo, and the headlights on and the air con compressor switched off.
I turned everything off and after about 30 seconds it stopped.
About 5 mins further on it did it again, and then stopped, and it didn't recur.
When I got home I got my meter out to check the voltage - no probs, 14v with the engine running.
The belt is also fine.
Howver, I did notice a weird noise coming from around the fan belt area, a kind of squeaking/rattling noise, the lights dimmed and the light flashed.
It seems like something is being loaded up and causing the belt to slip, so I'm now in 2 horror scenario's.
1: It's the alternator bearing about to sieze,
or, even worse..
2: It's the air-con compressor about to go tit's up.
I've got a long journey on Tuesday and I know my local garage won;t be able to look at it before then, so my question is, has anyone had this problem, and will it be OK. If it is the compressor, do they sieze, or just stop working?
Thanks for any advice.
Neil.
or, even worse..
Neil.
