Apr 15, 2009
2,188
Midlands
At the moment i have my clutch position switch out but i cant get it to stay in because theres so much pressure in the pedal it just forces it straight out when i release the clutch
can a worn clutch cause this??
it is slipping etc and being changed tomorrow
also my clutch pedal sits alot higher than the throttle and brake pedal and is a ball ache to use
is this due to having the switch out?
ive seen alot of people not notice there pedal switch has come out but never anyone mention the pedal going higher because of it
cheers
you should probably try a search. Very very common issue - broken weld on the pedal.. anyway - search or look in FAQs
i have searched
the broken pedal issue seems to drop the pedal to the floor from what ive read?
mines sits up higher than the brake and throttle
im still searching now trying to find some answers
just need to know if removing the clutch switch will make the pedal go high?
and
would a worn clutch make my pedal stiffer as i cant get the switch to stay in? it just shoots out as soon as clutch is released
oh right, thought you meant it goes right to the floor then back up past the other pedals...
It will defo be ready by then mate, clutch being done as we speak!
I'm hoping the new clutch will just solve it all and I can put the switch back in as normal lol
