Why does my lcr tick like a clock?
wilky87
154
Does anyone know what this box is for and why it ticks?
ThackersLCR
141
Blackpool
Good read! So when "The canister goes unused until the car is turned off again", why does it tick? Iv notice mine ticking more frequently now and mpg dropping, looking into it but welcome to sugestions.
wilky87
154
im guessing you remove the box and just join the inlet and outlet hose together
Apr 12, 2008
1,197
apple - how do you rip it out?
The vacuum to the inlet...block it off at the inlet
The electric conector, cut it off and bridgh the wire with a resistor (cant remember of the top of my head what ohm, 330 i think.)
And the thin pipe going to it is a breather from your fuel tank i believe i extended it and ran it down into the wing, just to keep it out of harms way!
That will remove it and not show up any codes on VagCom.
jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
could you leave it mechanically plugged in like the n249 or would it flag up?
when you say block it at the inlet is it just take th epipe off in the pic above and block there or traceit back a bit?
