Who's running Pro-sport coilies on a LCR???
B47t0n
162
Just fitted to my lcr
Brilliant ride honestly cannot fault them
Only down side I need : wheel spacers to clear the coilover nut
Also need shorted droplinks originals dont work
George657
479
Portsmouth
I'm running originals on mine?
Just place a jack under the wishbone, jack up, so the spring compresses and then place the drop link onto the locating plate.
B47t0n
162
The drop link seems too long unless this is normal ?
Are you running spacers too ?
B47t0n
162
The gap with no droplink between the arb and the shock tab is 330mm the length of my orginal drop links so u wouldn't even need to compress the spring to make it fit :S ill take a pic haha
George657
479
Portsmouth
But with the car jacked up the spring is under no tension.
Hence, jacking the wishbone up to bring the locating hole to approximate level.
That's how I did mine anyway.
B47t0n
162
Ill give it a blast pal see what happens thank you :)
Do you have 10mm front spacers ?
B47t0n
162
Where's the cheapest place to get some of these at the minute? DPM says they won't have any for a few weeks :/
I got mine from veedubmachine but I believe I got the last set I was struggling like mad to try find some
B47t0n
162
Just fitted vito 638 drop links and they work fine my only worrie is should the arb be under tension as I could move it up and down by hand with only the right hand side drop link attached
Priz91
Realist
Jun 24, 2013
197
Loughborough
I was thinking about buying these tbh.. So if i get them, i can run standard drop link by jacking the wishbone up and slotting the drop links into place. The get spacers as i was gonna put 15mm at the back and 10mm at the with standard cupra wheels?
