That's more confused than Scooby Doo. It's hard for me to remember the standard setup of these hoses but you should only have one check valve - the one on the left.
If I've worked this out correctly then the top-right vac hose with the heat-shielded sleeve going into that top check valve is coming from your actuator (second line on the K03) and should go straight into the top connection of your left-hand N112 (SAI valve).
If you follow the pipe that comes off the top of that left-hand N112 now it tees into this line, but where does that connecting vac hose go that goes out of sight under the charge pipe?
From what I can make of this you need to remove the line I just talked about (along with the check valve) and plumb the actuator line straight into the top of the N112 connection that should now be free - but I need to know where that other hose goes under the charge pipe?
If you look at
http://www.seatcupra.net/forums/showthread.php?t=106707&page=2 this bypass has already been done but you can see where the actuator line is supposed to plumb into the N112 as I described above.
