I nearly went a whole week with the car running more or less okay.
Having recently had abs unit replaced as well as the master brake cylinder (less than 200 miles ago), the car has just begun to whistle on acceleration. Once I held the speed steady, the noise would be a alot quieter. I gave it a run yesterday and after about an hour I had a very obvious lack of power where I believe the turbo stopped working. I stopped the car and started it up again, and then all was back to normal (still the obvious whistling sound when accelerating).
There is no smoke on acceleration or loss of power (expect for the once as mentioned above). Because the noise happened so soon after the master brake cylinder was fitted, and the air pipe thingy attached to the turbo was removed, I guessed it might be a loose connection, but the mechanic looked underneath it yesterday when parked on my drive (not jacked up) and said it was fine.
Any suggestions appreciated (it's a 2007 140bhp tdi). It's almost a year ago that I bought it, and it's run okish for about a whole month in total. I am considering buying a simple fiesta that will hopefully work ok most of the time and won't need me to go overdrawn to fix it.
