Which spring forge 007p
andytaylor1980
146
North East (Middlesbrough)
Hi i have had a quick search but cant find the answer i need, i bought my 007p DV from a member on here and just assumed that the correct spring would be fitted but then i thought what if he never had his LCR mapped ? so i think i should be using the yellow spring with a CC stage 1 is this the case ??
gulzar
LCR jabba'd
Oct 1, 2007
178
correct, yellow spring recommended for mapped lcr. i changed mine when i found out. if you want you can confirm with forge but no need as the yellow is the one to have. hope that helps ;-)
gulzar
Witalik
ROTTERDAM FEYENOORD
Dec 28, 2008
324
Netherlands
i also have the yellow spring fitted on my LCR but when i leave the throttle it hears like its blowing off 2 times, one time a little and then alot more. like its blowing 2 times... is that surge or do more guys have this
