Which oil do i need???
dutch200000
:wtf:anyone out there got a straight answer for me, i have lots of opinions but no one can tell me straight which oil to top up my 2008 cupra (under 5000 miles) with ,should it be fully or part synth,which brand and which weight??? help!!:confused:
BeakerCupra
Do you know what service interval your car is on? Vwg use different engine oil depending if the car is set to Longlife intervals (when the car tells you via message on the dash) or every 10k (Fixed intervals). Hopefully your service book will be stamped/marked to tell you which one you car is on?
Ian :)
Viking
Insurance co's are crap.
May 19, 2007
2,317
Near Richmond, North Yorks
It will tell you in your handbook. At a guess (and it's only a guess mind you) I'd say it's probably VW540/507 5W 30 full synthetic.
And just for info, Seat don't use the variable (longlife) service regime.
BeakerCupra
They don't? My apologies. Are they just on every 10k then?
Ian
Sep 5, 2009
569
Midlands
I reckon service intervals would be longer than 10k if they did use fully synthetic oil though, looking at my previous service reciepts the main dealer only use part synthetic oil, cheaper for them I suppose!!
mark1231
146
Engine oil grade SAE 5W/30 *
Engine oil classification OEM VW 504.00 *
Ambient temperature range All temperatures *
Viking
May 19, 2007
2,317
Use a different dealer mate. Should be full synthetic oil as far as I'm aware. Better still, do it yourself.
Sep 5, 2009
569
Midlands
All servicing that was done before I bought the car on reciepts by stoke seat and barlows states semi synth, if I was to change with say mobil 1 which is a long life oil I wouldn't fancy dumping that after 10k at 50 quid a change (done at home)! 10k change is a money spinner by SEAT as when I queried it they were very vague saying it should be done give or take a K or so! My motor will be out of warranty in march and Seat's 10k oil servicing will go with it!!
Viking
May 19, 2007
2,317
Mine gets an oil change every 10k miles with Gulf VW504/507 and a filter, total cost is about £25. Shop carefully and servicing costs napp all. All filters and oil change cost me less than £60.
Sep 5, 2009
569
Midlands
True, a decent motor trade counter halves the price of what you would pay from Halfords etc, I'll be using a fully synthetic 5w 30 when it is time, though the main idea behind a fully synthetic is longer service intervals, thus the reason my previous main dealer services have used semi knowing it will only be in for a max of 12 months.
