Which LED sidelights fit please?
Mark300zx
1,455
8
Surrey/SW London
I am thinking about getting some of the tower type but I am unsure whether they will fit, does anyone have these?
If not can you let me know what type you have, if you recommend them reliability wise, and the source?
Dec 6, 2008
612
Shropshire
its down to the diameter of the widest part of the bulb.
Basically as the sidelight holder is what secures the bulb to the light unit, the hole the bulb must pass through is what restricts it. The first set I ordered were 12.8mm diameter and were too big to pass through the hole, the second set were 11mm diameter and fitted in ok, as long as you get a bulb with the correct fitment at the base and less than 11 mm diameter it will fit in
