Hi all,
After just purchasing my LCR and taking it a decent drive to see what it can do, I have discovered that the clutch is slipping in 5th and 6th if you plant your foot.
So what I would like to know is which clutch is recommended and whether or not to change from dual mass to single mass flywheel?
My idea would be to hopefully just replace the actual clutch with a slightly uprated one, I have read on here that Sachs is a good upgrade?!
Is there anything else worth changing at the same time?
David
David
