Which Bulbs
on_the_verge
214
Hi,
Wanting to change the headlight bulbs on my fr when it arrives, what are the ones that give the blue/white light that are near xenons?
Ta
Virge
Mar 26, 2007
713
Norn Iron
If you search theres a few topics on this would be good reading for you. But in short I changed my bulbs to the phillips 80%+ (I think thats what they were) they are a great job. Changed the side lights to whiter as well
dabcabc
Just received my H7 HID kit from hong kong, along with some blue vision H1 / 505's for main beam / side. Got some relays so I can bypass the "light blown" warning - damn ECU. I'll document fitting them if anyone would find it handy.
Rampage
Trainee Northener
May 24, 2003
1,035
Do you wire the coil of the relay into the bulb circuit then have to run another constant +12v the switch side of the relay?
dabcabc
I imagine you could do it the same way, or add a resistor to the circuit to bring the load up.
dabcabc
Just fit my blue vision side / main beam. Just the HID's to fit now :)
The following show new versus old.
on_the_verge
214
So you can get the blue vision in the dipped is it H7? As they look good, although was thinking of getting the Philips Diamond Vision bulbs
Moley RUFC
Up in the Lickeys........
Nov 20, 2006
1,232
Lickey,Worcs
I have just changed my Blue Vision to X-Treme 80% bulbs. I had the Blue Vision ones in for a bout a year and although they seemed okay the light from the X-Tremes' is so much brighter and whiter!!
I did keep my Blue Vision side lights in though
on_the_verge
214
Saw a BM 1 deries yesterday with normal headlamps and the light being thrown out was so blue, looked really good, just what I want......
k4ith
Goodson!
Sep 3, 2006
746
West Lothian
halfords are doing buy one get one free on their pure brilliance range nice white blue, fitted them and defo improvement over oem ones, had the phillips night in my leon but while they were good they weren't great.
Jace
Sneaker Freaker
Just fitted both Main & dipped OSRAM Night Breakers to the car
(& I took pics of the fitting process -guide to follow)
Dipped
Main Beam
I also changed the indicator bulbs for some Chrome ones, but they arent that bright, so time for some Silver Stars I think, but at least I know how they come out now :clap:
LEFT : Philips...................................................RIGHT: Osram
Note how much "fatter" the osrams are, maybe th eextra blue band at the bottom adds to the effect ??
dabcabc
Fitted my HID's to my car today - they make my philips bluevision side lights look yellow!
