Where is it?
Jules
37
Hi all, I realise this is a silly question but please can some-one explain or post a pic of where the Lambda sensor is that would cause this fault 16514 P0130 O2 Sensor Circ.,Bank1-Sensor1 Malfunction is located please. Would a cheap one do the job? The car is a 2002 Leon Cupra 1.8T 20v with no modifications. Thank you
nd-photo.nl
3,668
22
The Netherlands
www.nd-photo.nl
The lambda sensor sits on the downpipe. The 20VT has 2 lambda sensors, one which measures exhaust gases and a "control" lambda.
ToyosportsDownpipe_NDPHOTO_20121026_001_1 by ND-Photo.nl, on Flickr
The bottom one is the stock downpipe, you can see the lambda connection in the neck.
Get a proper one, get OEM or correct Bosch. Correct fueling is important as you might suspect...
Jules
37
Thank you for the reply. I will look at getting a Bosch replacement, will I need to replace both?
Jules
37
Dont have access to Vagcom, well only a free version that reads/clears faults. Will just replace the front one and see. Thanks for the advice :D
