Where does this vac pipe go?
This pipe, that comes off the top of the N112 valve (I think thats the valve, top left of coil packs) then it's t-pieced onto the top of the actuator.
You can see in this pic the pipe come from the left (off the the top of the N112 valve) then the t-piece leading to actuator.
Now, my question is, where does the pipe going to the right go? Mines just doesn't go anywhere and looks like it's snapped and frayed off :shrug:
T-piece leads down to actuator.
Any help much appreciated as my 10-14psi has had me a bit baffled since I got my boost gauge. Also would this explain engine management light on but car running fine? I have vagcom but need to setup laptop to run it.
