where can i get megasquirt ecu and instalation?
jcs356
Cordy owner
Jul 12, 2004
1,161
Englandland
I've not heard good things about megasquirt. As m0rk says, they need a lot of work to get them up and running properly.
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Toyotec is still a regular on club gti. You won't find many tuners willing to fit megasquirt to your car though. Get yourself on google and have a search around about it. Why do you want megasquirt anyway?
Kai_1600
Shallow
Dec 10, 2005
410
Manchester
well time wil tel guys , as ive sent the ecu off to upgrade to the ms2 ecu ,,, heres some info if any off u fancy runing standalone ms
heres the link guys ,(for runing standalone megqsquirt ms1/2)
just contact phil on his homepage highly recomended guy, very helpfull, with help/suport, and he will suject best ecu for ur engines setup ,
(you,ll see a caddy pic of mine on there too, 27psi on a stand alone ms2 ecu ,,,
http://www.extraefi.co.uk/
http://www.extraefi.co.uk/gallery.htm
thought this would be of use as theres loads of standalone systems out there which are pricey to buy, the kits are brand new, and assembled to a high standed, as complete with labled wireing loom, instalation cd, etc ,,,as i know this kit was setup and tunied and runs/boosts a treat , once the niggy tunieing parts were sorted out ,,,
From a thread i think you've read/posted in.... search button broken today? ;)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Definitely if you're running a 20VT, use the OE setup where possible. Well worth it.
QPE is 'nice' but not cheap - it won't give you the control, or safety the OE has
Megasquirt (from experience) is a laugh to build & setup if that's your mindset, but the wiring was such a pain in the ass. It appealed to my mindset, but it wasn't easy going.
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
i've been lookin into ms and it seems it a pain in the back side to set and takes alot of time
As with all stand alone ecu's. One easy way to do the conversion other than swapping dashes etc too would be to get the immobilizer removed from the ECU although leaving your car a little less safe.
