wheels
ZiggyEP3
406
72
UK
I'm not an expert for wheels but I can see that rim width and offset being a problem especially with the 35mm drop in the suspension
R3k1355
1,819
258
Yorkshire
https://www.willtheyfit.com
This will give you an idea of the fitment, you can then use the measurements to gauge how much more space the new wheels will take up.
wheelimage.php
From the image it looks really close so you shouldn't have too much of a problem, if the ET is too high a 5mm slip on spacer might give you the clearance needed.
