Wheel bearing issues?
Cupra_J_RS
Yellow Perril Cupra
May 14, 2007
402
Solihull, Birmingham
Afternoon all,
I'm 90% sure one of my wheel bearings needs replacing BUT...other than the 'squeeling' noise is there any other tell tail signs of a worn bearing? My car does some to 'whine' more now than in the past...but that might be all in my mind.
And is there anyway i can work out which wheel it is?
A high pitched squeeking sound can be heard coming from the passenger side, but not sure which wheel, and it doesn't always squeek.
How much to get it replaced, i.e. cost of parts?
Is it something i'd be able to do in my garage with the right knowledge?
Any info appreciated!!
James
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
Tell tell signs are grinding when your turning.
Should cost about £20 from ECP for the bearing then take the complete hub to a garage to get the bearing pressed in. Unless you have access to a hydraulic press that is
Dec 13, 2006
724
Ashford, Middx
I changed my rear wheel bearings the other day, they were £100 for both. Wasn't expecting them to be quite as exspensive but it included the hubs aswell.
RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.Oxford7s.net
I think one of my rears might need doing now.. If I jack the car up, is there an easy way to tell (i.e. play in the horizontal axis?)
What sort of job is it... I've got some skills but work better with a guide - any pointers or existing guides?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
clear area and drive steady in a slalom effect to see if the noise alters at all
sometimes the extra stress can make a grumbling bearing quieter/louder as you push on and off it
