What's this engine part ?
PhilOfCas
478
The capital of Yorkshire
Evening all :)
Whilst under the car the other day, I looked up under the engine and saw an aluminium (I think) box approx 4" cubed, it had a large black plastic cap, which pointed down (and is obviously undone from beneath the car), this was over to the passenger side.
It has ribbed sides, anyone know what it is ? :shrug:
Thanks !!
Viking
Insurance co's are crap.
May 19, 2007
2,317
Near Richmond, North Yorks
No it doesn't need cleaning although you can if you wish. But don't use solvent cleaners. Best way is to wipe it with a damp cloth and a mild mix of Meguiars APC, and then buff with a dry cloth. Should polish up nicely. :D
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
IF it was underneath the oil filter bracket then it is the oil cooler, which cools the oil by contact with the engine coolant (so an oil-water heat exchanger). On your engine this is attached to the bracket by something that looks similar to an oil filter cap, which matches your description and location. However you're a bit vague - can you look down at the same location from on top of the car and see if it's where the oil filter is?
PhilOfCas
478
I can be very vague sometimes :D, yep, just had a butchers in the garage, it's beneath the oil filter house, 2 pipes in the top of it, through my powers of deduction i believe you have it spot on :), cheers Muttley and all
