what leangth wheel bolts 20mm spacers?
pg glasgow
119
can anyone tell me what leangth wheel bolts should be used when fitting 20mm spacers.i have 35mm ones just now from a set of smaller spacers but not sure if they are long enough
Benny the bear
Hi, i have 20mm spacers, pretty sure i got 50mm bolts for them-they fit just fine.....new tyres going on tomorrow=so i can check and get back to you. a note though-after about 100 miles check your bolts have not come loose-its a common problem iwas told. cheers
pg glasgow
119
i thought they should be longer than 35mm ill give the guy who sells them a bell tomorow and see what he recomends.thanks mate.
Benny the bear
Hi, i have 50mm bolts. Originals were 25mm, so theres 5mm hiding somewhere but ive had no problems with them.
Benny the bear
Yep, same here.......ive put my nut caps back on though (had to order two new) Have you ever tried getting those things off in a hurry? impossible---
more securr than the locking nut :) However
If someone wants ya wheels-there as good as gone....no matter what locking nuts you have.
