what gauges?
gazjones
right today ive fitted a boost gauge by auto gauge works well and looks good but i am after two more gauges and will be getting a tripple din gauge holder that is angled towards the driver just wanting thoughts on what other gaugest would be good, its for an fr 20vt. thanx for any suggestions gaz
gazjones
dad has one in his clasic car its a thermal sensor like a water temp sensor dont run a pipe as such with them
gazjones
the pressur one runs a very small pipe only about 1 mill thick so not much oil at all goes through it workes on my dads classic car with on prob they are fastend in place with locking type nut the screw into gauge and clamp on the pipe os wont pop off
Jan 14, 2005
1,308
Cannock/Wolvo
Where you gettin your tripple din gauge holder from??
gazjones
got it off ebay 20 quid the place its from is swg motorsport they do all golf stuff and is 40 quid from them
Jan 14, 2005
1,308
Cannock/Wolvo
gaz have you conected your boost pipe to the top of the dv? if so do you have any pics
gazjones
yes a connected it to the top of the dv cut the standard pipe in two then fitted a t pice between each bit of pipe not hard to do will try and take a pic soon if weather improves mate!
chall
how about oil pressure and air/fuel mate
i seen the din gauge holder in venommotorsport for about 20 odd squid
hon_n_gem
Candy White K1
Mar 22, 2006
1,132
Kent
www.auto-tuner.co.uk
im looking to get a triple gauge din thingy too! how much does fitting cost? because buying three gauges and the plate will run in around 150£ dont realli wanna be spending too much more to get it fitted!
Hon
depresion
484
On a turbo petrol I'd run
Boost
Air/Fuel
Oil Presure
Probably costing £170-250
on a TDI
Boost
EGT
Oil Presure
Probably costing £350+ (EGT guages are hugly expensive)
gazjones
of mine ill try and find one on my phone not great quality but will try and load it up
gazjones
no pics on phone will take some tomorrow and post them up bunnin!
