What fuse is it?
Gooner_Mike
Teaching the kids
Jan 20, 2008
4,363
Hampshire
www.facebook.com
Changing sidelight bulbs today and I have shorted out the passenger side one! The LED bulb was a git to get in so, like a retard I got my long nose pliers to try and open up the contacts a bit inside the bulb holder.... :doh: Can't believe I did it now but there you go. [:@]
Anyway, the sidelight and rear lights do not want to work now! I looked at the fuse diagram but I am non the wiser to be honest. Can anyone direct me to a way of solving the problem, or which fuse I need to change please.
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
o dear! i cant help with which fuse as mine does not have a fuse card but you could just look and find the fuse
st10587
Oct 4, 2007
3,669
Hindhead
i think its fuses 6 and 7
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Well if you've got a multimeter just test them all.
Put it on ohms and check the fuses, if its dead it will say 0 or OL. If its good it will be something like 0.2/0.3ohms.
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
Don't go removing fuses willy nilly, this can cause an air bag fault if you pull the wrong ones. make sure you disconect the battery for a while first.
TBH you should be able to see a blown fuse without removing it any way.
Nath.
Jan 1, 2006
8,620
16
If you shorted the live and earth together with a pair of long nosed pliers I would guess that there is a fuse that has totally blown. Probably 6 or 7 on that chart above. it's just working out the orientation of the chart and fuse box or having a good look for a smoked look fuse.
Gooner_Mike
Teaching the kids
Jan 20, 2008
4,363
Hampshire
www.facebook.com
Cheers. Going to get cracking with it this in a bit! Finishing my boost gauge fitment too hopefully.
