What does the clutch switch actually do?
Feb 26, 2009
5,275
Wolverhampton
On my car it sends a signal to the cruise control to disengage when the clutch is pressed, but it can be there even if cruise control isn't fitted as standard.
On some other cars it prevents the car from being started unless the clutch pedal is held down, although I'm not sure that applies to SEAT.
Jul 4, 2007
1,674
bristol
it just tells if the clutch is up or not. dont know 100% why i think its something to do with the revs. if its in the wrong place the revs can go up 500 for no reason when changing gear. someone might correct me.
stuibaby
MK3 Cupra Driver - Proud!
Aug 14, 2009
317
Bristol/Bath
Thanks guys,
i did notice when i change gears sometimes, the revs either stay where they were or rise slightly,
Is this what causes it?
Aug 29, 2010
587
suffolk
Mine do that welded a nut onto the metal where it screws in so it doesnt pop out anymore sorted
