what do you think of this bit of power routing....
Phil_beeza
461
just did this.
fuse sitting on top of battery. power cable tied to earthing wire which was already there.
both bulkhead holes grometted (inner one was such a pain)
tidy/functional/safe ??
Baz1
216
Leicester
Looks ok Phil.
Altho in the 2nd pic try to get a grommet into the 2nd opening - or even some sealant as you deffo DONT want water to go thru there, as it might do.
Phil_beeza
461
for sure, both holes are actually grommeted, the inner one has a small thin tough plastic u shaped strip on it.
originally wanted 2x 4 gauge size thro there but just going with power + 4 other small wires now, so might have enough room for a standard chunky gromet. may revisit this later anyhows :)
im definitely going to fill up with sealent too
Baz1
216
Leicester
I got 0awg through there easy, although not the second inner hole, I used a different on for the inner skin, never even saw that one.
And where is this sacred hole? lol Do you have pics of how you have routed yours please? I need to run 0awg power and earth directly frm the battery to the back so need to see where else is available.
Baz
