Run VAGCOM on my car as it sounded like it was misfiring under load. And slightly lumpy (Subaru) on tick over. I read on here that the maf is a constant pain so tried unplugging it to see if it ran any better but didnt and the yellow dash light came on so plaugged it back in and it went out.
Then ran VAGCOM and these 2 faults came up. To make sure it wasn't because I unplugged it earlier I cleared the 2 faults and run it again but the same two came up as below
16486 PO102 Mass or Volume Air Flow Circ Low input
16501 P0117 Engine Coolant Temp Circ Low input
What do these 2 mean and would they cause the symptoms I described ?
Car is totally Standard by the way !!
Cheers in advance !!
LEE
LEE
