what charge pipe are people using..
May 16, 2008
506
southampton
i am wanting to know what charge pipe u people are using its the one that goes down the side of the engine like lcr ones and where to get it from as thinking of changing my pipe work route to intercooler..
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
LCR one will fit with a 90 degree reducer 60 - 51 I think it was on the turbo side.
Then a 90 degree down the wing on the left. NOTE: you will need a smaller whiper fluid reservoir (donno what its called in english). Get one from a golf 2. I just fitted mine last saturday.
I am doing the same as danny, except I'm welding it all, so no silicone in the bay (on charge pipe that is).
May 16, 2008
506
southampton
the only thing i see with the lcr one is by the turbo it has a larger silincer looking bit thats the only thing putting me off as dont know what u have to do with that bit. and its a washer fluid bottle in english mate .
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
thats the reason why I ended up not going for the LCR pipe.
I bought that then opted against it.
just ran out to the garage to take a pic of the 2
LCR pipe:
(excuse the mess)
then what I'm working on:
90 degree 60mm bend in which I drilled 2 holes. 1 8mm 1 25mm.
You will need to buy 2 hose connectors in those same sizes. 1 for N75 1 for your dumpvalve.
Then stick 2 90 degree bends on the those, and get welding.
May 16, 2008
506
southampton
the lcr one im thinking may be cut that bit off and try weld a extention bit on posibly how much u pay for the lcr pipe mate .... also just been reading your reader ride danny and you done loads mate changed nearly every thing its taken me age to read your pages 30 plus ...
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Yup ive replaced nearly everything...Enjoyed it too..
How wide is the LCR charge Pipe Mines 63mm ID...Same with my Throttle bodie side too
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
yes, if you use the LCR one, I would cut off the muffler. Most do. I would because my k03s is also silenced. no point in 2.
As for welding a pipe on that, I'm pretty sure you;ll never get it polished quite the same as the rest. LCR pipe is thicker metal. the other pipes will be aluminum. Also, the lcr pipe comes in a coating so quite some work to polish.
LCR pipe here in Netherlands costs 90 euro's without the brackets.
3 90 degree aluminum bends: 45 euro's. 8mm and 25mm nipple: 6 euro's. Welding: time or possibly 30 euro's.
up to you
Danny, LCR is 60mm outside
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
lol well with current exchange rate about 82 quid lol.
yes it is for sale, but shipping will be immense to the UK.
Have a look see on the web near you. there's always peopel selling these. the LCR pipe is the same as the S3 and TT 225hp model.
