what camshafts for GT35r ar 0.82?
BIG_Y
95
Israel
to go on the Cat Cams 3658?
or the 3652?
What is the difference between, 3652 and 3658?
What RPM Is 3658 good, what RPM the other good?
i use the stock ecu!
ty!
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
My catcam specs in my GT35R ibiza are:-
My specs... just so they're in the same catcams thread. - comparison
3651 -----> My specials
Duration: 245 / 262° ----->246 / 268°
Valve Lift: 8.25 / 9.95mm ----->10.00 / 9.25mm
Peak Angle: 113° / 108° ----->
Timing: -9/36° / 36/-1° ----->
Lift @ TDC: 0.30 / 0.95mm ----->0.26 / 1.51mm
ENGINE TYPE : AUDI 4cyl20v Turbo
INLET EXHAUST
Valve clearance (hot) : 0.00 mm 0.00 mm
(cold) : 0.00 mm (+0,00 / 0,05) 0.05 mm (+0,05 / 0,10)
CAM LIFT : 9.25 mm 10.00 mm
ROCKER ARM RATIO : 1.00 1.00
VALVE LIFT : 9.25 mm 10.00 mm
DURATION @ 0.1mm Valve lift : 268 ° 246 °
DURATION @ 1.0mm Valve lift : 226 ° 210 °
PEAK DIFF.: maxlift @ : 108 ° ATDC 116 ° BTDC
Valve lift at TDC w/o clearance : 1.51 mm 0.26 mm
1. w/o clearance at : 0.10 mm valve lift 0.10 mm valve lift
Valve opens : 21 ° BTDC 56 ° BBDC
Valve closes : 67 ° ABDC 10 ° ATDC
2. w/o clearance at : 1.00 mm valve lift 1.00 mm valve lift
Valve opens : 6 ° BTDC 41 ° BBDC
Valve closes : 41 ° ABDC -11 ° ATDC
VALVE SPRINGS
partnr. : - -
fitted length : - mm - mm
RETAINERS partnr. : - -
CAM FOLLOWERS partnr. : - -
REMARKS : B/A TDC= before/after top dead centre
B/A BDC= before/after bottom dead centre
More discussion on Cams here> http://www.elitedubs.com/index.php/topic,1961.0.html
Code:
partnr.
 duration
 duration
 maximum lift
 lift at TDC
 parts
 application
[data link]
 [0.1mm+cl]
 [1.0mm+cl]
 [cl=0]
 [cl=0]
 (TURBO)
1013651
 245 / 262°
 207 / 217°
 8.25 / 9.95mm
 0.30 / 0.95mm
 O.E.M.
 HYDR: sport
1013653
 239 / 246°
 214 / 220°
 8.80 / 10.85mm
 0.70 / 1.25mm
 O.E.M.
 HYDR: sport
1013652
 268 / 282°
 226 / 233°
 9.25 / 11.00mm
 1.30 / 1.95mm
 O.E.M.
 HYDR: sport
1013658
 268 / 263°
 226 / 217°
 9.25 / 9.95mm
 1.30 / 0.95mm
 O.E.M.
 HYDR: sport
ryan_s3
1,270
So little duration and lift for a gt35 ! I'm so suprised you've not experienced any surge in 4th and 5th on a 1.9.Your head must be very good!
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
no surge experienced yet, but thats on the dyno.. on the road its spinning up on road tyres.
will see what slicks do to try and put power to the ground saturday
AVIHAI-TOPOR
BIG Y car use OEM pistons and AGU ported head with gt3540 ar.82 We want to boost 1.9-2.1 bars and get 450-480whp with w/m kit
ryan_s3
1,270
The .82 housing helps with surge,as does headwork,cams,inlet manifold,throttle body. Good luck on saturday,low boost to start i reckon.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
stock pistons...... :headhurt:
good luck
hope they hold out
35psi boost on my JE's, 8.5:! CR on 35R full chat to 9000rpm holds boost alll the way.
crazy-obscene for 2wd
AVIHAI-TOPOR
we get the parts from QED POWER today
Calico Coated Rod Bearings
+.001 ACL race series bearings.
CAT hydraulic cast camshaft set
CAT Valve Springs, set
CAT Adjustable Cam Sprocket
Intake Valves, black nitrided Single Groove Keeper
Exhaust Valves, Inconel
Titanium Retainer
SuperTech manganese- bronze Valve Guides
Hydraulic Valve Lifters (All) 12 intake, 8 exhaust
now we wait for the SEM manifold with 80mm TB and the AGU head
