Hey chaps,
I did use the search function.
Mainly this issue is caused by a leaky door? Loads of threads on ibiza's / leons.
If I press down on the carpet - I can get a good cm of water.
I've checked for any leakage of wet signs running down to the footwell.. but it's bone dry! Nothing at all.
I'll be taking the door seals off tomorrow to double check. Also be checking the pollen filter (read on the leon this may cause a wet floor?)
Whilst I'm out there, any other ideas?!
:edit:
p.s - a while back I posted about my brake lights! It seems, now every so often there's a light failure (dashboard tells me).... the Left hand side - Side light doesnt work... nor does the left hand side rear light.
Sometimes - this starts working again.. so a faulty connection? Could this be something to do with the wet footwell?
:edit:
