Help.
One of my colleague has a standard TT225 and it won't run more than 0.3 bar boost.
Error code of pressure loss between turbo and throttle body. Check DV
DV is fine, maf is a known good one, and reading 190g/s max, with n75 duty cycle of 80%.
All of it suggests a massive boost leak, but the fuel trims are spot on at 0.0 and 0.8,
Also a boost leak this big should be obvious and noisy.
I've checked all the visible hoses and had a quick feel around the ones you cant see, and can't find anything. Also all the vac piping seems ok. All clean with no tell tale oil on them from leaks.
Anyone got any ideas on where cupra r pipework leaks, or ever seen a split intercooler? Any suggestions.
